Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Ring Setting (Phone Idle / Phone Active) System Default
Hi all,
When configuring the lines on an IP phone you can specify the "Ring Setting (Phone Idle)" and "Ring Setting (Phone Active)" parameters. One of the options you can choose is "System Default".
My question is where do you set the "System Default" for these two parameters? I can't seem to find it.
Thanks in advance for any assistance.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Ring Setting (Phone Idle / Phone Active) System Default
Hey Steven,
You have to dig deep for these ones :)
From ccmadmin;
Service>Service Parameters>Callmanager Service>Clusterwide Parameters (Device - Phone)
You will see the settings options here.
Hope this helps!
Rob
Hey Steven,
From ccmadmin;
Hope this helps!
Rob
Hi,Im trying to look for this
We run system version 9.1.2.11900-12
It is now in  System>Service Parameters>Select Server>Cisco Callmanager Service>Clusterwide Parameters (Device - Phone)
Cheers
Adam
3075
