You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Ringback delay
All,
Could Somebody say me if there is some command for ringback time?
The called number ring first and the calling number hear only after the second ring.
Configuration:
card type e1 0 0
card type e1 0 1
card type e1 0 2
card type e1 0 3
card type e1 1 0
card type e1 1 1
card type e1 2 0
enable secret 5 $1$Bc4v$WASyazVGnuuiYDBAP/LRb1
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate slot 2
network-clock-participate wic 0
network-clock-participate wic 1
no network-clock-participate wic 2
no network-clock-participate wic 3
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 E1 0/1/0
network-clock-select 4 E1 0/1/1
trunk group PSTN
trunk group PABX
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
voice-card 2
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice class h323 1
  h225 timeout tcp establish 3
  h225 connect-passthru
  h225 h245-address on-connect
  no h225 h245-address setup
  no h225 h245-address on-progress
  no h225 h245-address on-alert
  h225 h245-address facility
  h225 h245-address progress
  h225 h245-address sync
  no h225 h245-address on-setup
  call preserve
  telephony-service ccm-compatible
  ccm-compatible
voice translation-rule 1
rule 1 /^\(....\)/ /613105\1/
voice translation-profile IncomingPABX
translate calling 1
voice translation-profile IncomingPSTN
translate called 1
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  double-answer
  answer-signal group-b 1
  trunk-group PSTN
description ### CONEXAO COM PSTN ###
controller E1 0/0/1
framing NO-CRC4
cas-custom 0
  country brazil
  metering
  double-answer
  trunk-group PABX
description ### CONEXAO COM PABX ###
controller E1 0/1/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
  country brazil
  metering
  double-answer
  trunk-group PSTN
controller E1 0/1/1
framing NO-CRC4
cas-custom 1
  country brazil
  metering
  double-answer
  trunk-group PABX
controller E1 0/2/0
controller E1 0/2/1
controller E1 0/3/0
controller E1 0/3/1
controller E1 1/0/0
controller E1 1/0/1
controller E1 1/1/0
controller E1 1/1/1
controller E1 2/0/0
controller E1 2/0/1
class-map match-any VIDEO_IN
match access-group name VIDEO
class-map match-any NETWORK-CONTROL_OUT
match  dscp cs2
match  dscp cs6
class-map match-any VOICE-CLUSTER
match access-group name VOICE-CLUSTER
class-map match-any REAL-TIME_OUT
match  dscp ef
class-map match-any MISSAO-CRITICA_IN
match access-group name MISSAO-CRITICA
class-map match-any VIDEO_OUT
match  dscp af41
class-map match-any CALL_SIGNALING_IN
match access-group name CALL_SIGNALING
class-map match-any NETWORK-CONTROL_IN
match access-group name NETWORK-CONTROL
class-map match-any MISSAO-CRITICA_OUT
match  dscp cs3
match  dscp af31
class-map match-any NETWORK-ROUTING_IN
match access-group name NETWORK-ROUTING
class-map match-any REAL-TIME_IN
match access-group name REAL-TIME
policy-map QOS_IN
class REAL-TIME_IN
  set dscp ef
class MISSAO-CRITICA_IN
  set dscp af31
class CALL_SIGNALING_IN
  set dscp cs3
class VIDEO_IN
  set dscp af41
class NETWORK-ROUTING_IN
  set dscp cs6
class NETWORK-CONTROL_IN
  set dscp cs2
class class-default
  set dscp default
policy-map QOS_OUT
class VOICE-CLUSTER
  police 10000000
class REAL-TIME_OUT
  priority percent 15
class MISSAO-CRITICA_OUT
  bandwidth percent 31
  fair-queue
  random-detect dscp-based
class VIDEO_OUT
  police rate percent 18
class NETWORK-CONTROL_OUT
  bandwidth percent 1
class class-default
  bandwidth percent 14
  fair-queue
interface Loopback0
ip address 192.168.64.167 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.64.167
interface Embedded-Service-Engine0/0
no ip address
ip access-list extended CALL_SIGNALING
permit tcp any any eq 2000
permit tcp any eq 2000 any
permit tcp any any eq 1720
permit tcp any eq 1720 any
permit tcp any any range 5060 5061
permit tcp any range 5060 5061 any
permit udp any any range 5060 5061
permit udp any range 5060 5061 any
ip access-list extended MISSAO-CRITICA
permit tcp any any eq 1494
permit udp any any eq 1494
permit udp any eq 1494 any
permit tcp any eq 1494 any
permit tcp any any eq 2598
permit tcp any eq 2598 any
permit udp any eq 2598 any
permit tcp any eq 1521 any
permit tcp any eq 1526 any
permit tcp any eq 1530 any
permit tcp any any eq 1521
permit tcp any any eq 1526
permit tcp any any eq 1530
ip access-list extended NETWORK-CONTROL
permit tcp any any eq telnet
permit tcp any eq telnet any
permit udp any any eq snmp
permit udp any eq snmp any
permit tcp any any eq tacacs
permit tcp any eq tacacs any
permit tcp any any eq 123
permit tcp any eq 123 any
ip access-list extended NETWORK-ROUTING
permit tcp any any eq bgp
permit tcp any eq bgp any
ip access-list extended REAL-TIME
permit udp any any range 16384 32767
permit udp any range 16384 32767 any
ip access-list extended VIDEO
permit ip 10.248.4.0 0.0.0.255 any
ip access-list extended VOICE-CLUSTER
permit ip 192.168.4.0 0.0.1.255 any
voice-port 0/0/0:0
translation-profile incoming IncomingPSTN
cptone BR
timeouts interdigit 3
timeouts call-disconnect 1
voice-port 0/1/0:1
cptone BR
voice-port 0/0/1:0
translation-profile incoming IncomingPABX
cptone BR
voice-port 0/1/1:1
cptone BR
sccp local Loopback0
sccp ccm 192.168.4.13 identifier 1 version 7.0
sccp ccm 192.168.4.14 identifier 2 version 7.0
sccp ccm 192.168.4.15 identifier 3 version 7.0
sccp ccm 192.168.4.16 identifier 4 version 7.0
sccp ccm 192.168.8.11 identifier 5 version 7.0
sccp ccm 192.168.8.12 identifier 6 version 7.0
sccp ccm 192.168.8.13 identifier 7 version 7.0
sccp ccm 192.168.8.14 identifier 8 version 7.0
sccp ip precedence 3
sccp
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729br8
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 3
dial-peer voice 1 pots
tone ringback alert-no-PI
description PSTN
incoming called-number .
direct-inward-dial
forward-digits all
dial-peer voice 2 voip
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 media
dial-peer voice 11 voip
description ### DIAL-PEER VOIP PARA CUCM 1 ###
preference 1
destination-pattern .T
session target ipv4:192.168.4.13
voice-class codec 1
voice-class h323 1
dial-peer voice 12 voip
description ### DIAL-PEER VOIP PARA CUCM 2 ###
preference 2
session target ipv4:192.168.4.14
voice-class codec 1
voice-class h323 1
dial-peer voice 13 voip
description ### DIAL-PEER VOIP PARA CUCM 3 ###
preference 3
session target ipv4:192.168.4.15
voice-class codec 1
voice-class h323 1
dial-peer voice 14 voip
description ### DIAL-PEER VOIP PARA CUCM 4 ###
preference 4
session target ipv4:192.168.4.16
voice-class codec 1
voice-class h323 1
dial-peer voice 15 voip
description ### DIAL-PEER VOIP PARA CUCM 5 ###
preference 5
session target ipv4:192.168.8.11
voice-class codec 1
voice-class h323 1
dial-peer voice 16 voip
description ### DIAL-PEER VOIP PARA CUCM 6 ###
preference 6
session target ipv4:192.168.8.12
voice-class codec 1
voice-class h323 1
dial-peer voice 17 voip
description ### DIAL-PEER VOIP PARA CUCM 7 ###
preference 7
session target ipv4:192.168.8.13
voice-class codec 1
voice-class h323 1
dial-peer voice 18 voip
description ### DIAL-PEER VOIP PARA CUCM 8 ###
preference 8
session target ipv4:192.168.8.14
voice-class codec 1
voice-class h323 1
dial-peer voice 20 pots
trunkgroup PSTN
description ### DIAL-PEER POTS REDUNDANCIA PSTN ###
preference 9
fax rate disable
dial-peer voice 101 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA LOCAL FIXO ###
destination-pattern [2-5].......
fax rate disable
dial-peer voice 102 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA LOCAL CELULAR ###
destination-pattern [6-9].......
fax rate disable
dial-peer voice 103 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA DDD FIXO ###
destination-pattern 0[1-9]...[2-5].......
fax rate disable
prefix 0
dial-peer voice 104 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA DDD CELULAR ###
destination-pattern 0[1-9]...[6-9].......
fax rate disable
prefix 0
dial-peer voice 105 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA DDI ###
destination-pattern 00T
fax rate disable
prefix 00
dial-peer voice 106 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA 0500 ###
destination-pattern 0500T
fax rate disable
prefix 0500
dial-peer voice 107 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA 0300 ###
destination-pattern 0300T
fax rate disable
prefix 0300
dial-peer voice 108 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA 0800 ###
destination-pattern 0800T
fax rate disable
prefix 0800
dial-peer voice 109 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA SERVICOS ###
destination-pattern 103T
fax rate disable
prefix 103
dial-peer voice 110 pots
trunkgroup PSTN
destination-pattern 1T
fax rate disable
prefix 1
dial-peer voice 111 pots
trunkgroup PSTN
description ### DIAL-PEER POTS CHAMADA EXCLUSIVA FAX ###
destination-pattern 1111[2-5].......
fax rate disable
dial-peer voice 112 pots
trunkgroup PSTN
destination-pattern 1111..T
fax rate disable
prefix 031
dial-peer voice 1001 pots
trunkgroup PABX
description ### DIAL-PEER POTS CHAMADA ENTRADA PABX ###
destination-pattern 613105[5-7]...
fax rate disable
forward-digits 4
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.64.167 port 2000
max-ephones 300
max-dn 600
system message primary SOBREVIVENCIA LOCAL
system message secondary SOBREVIVENCIA LOCAL
transfer-pattern .T
call-forward pattern .T
time-zone 17
time-format 24
date-format dd-mm-yy
Luciane de Medeiros
  • IP Telephony
Everyone's tags (2)
1 REPLY
Ringback delay
All,
The problem is solved with the following commands:
PSTN
dnis-digits min 1 max 4
dnis-complete
answer-guard-time 250
Luciane de Medeiros
656
