Ringback tone issue CUCM to H.323-PSTN GW
Good day.
I'm a bit confused, everything works well in my setup except ringback tone for outbound calls. I've followed this instructions -
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml
but without luck...
here is debug h225 q931 and isdn q931
Q931 Message IE Decodes
Protocol Discriminator : 0x08
CRV Length             : 2
CRV Value              : 0x0002
Message Type           : 0x05: SETUP
Bearer Capability: Length Of IE=4
Data 881886A5
Calling Party Number: Length Of IE=6
Data 008137303031
Called Party Number: Length Of IE=12
Data 803839313636303437383031
User-User: Length Of IE=196
Data 0520B0060008914A0005020180A334401F0037003000300031000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010500BC49937AB34000681AAA7974312102003102C0A8311C00D50D80000700AC1004F106B8110000681AAA7974312102003102C0A8311C010001000100010010A00100140140B50000120D82040020040001030003000103
*Aug 20 14:02:12.062: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 2174777
*Aug 20 14:02:12.062: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 89166047801
*Aug 20 14:02:12.062: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838F
                Exclusive, Channel 15
        Calling Party Number i = 0x0081, '2174777'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '8916604XXXX'
CRV Length             : 2
CRV Value              : 0x8002
Message Type           : 0x02: CALL_PROC
User-User: Length Of IE=57
Data 0521C0060008914A00042800B500001240013C050100000A141F02E5F2110C110000681AAA7974312102003102C0A8311C0100010010800100
*Aug 20 14:02:12.110: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8089
        Progress Ind i = 0x8088 - In-band info or appropriate now available
CRV Length             : 2
CRV Value              : 0x8002
Message Type           : 0x03: PROGRESS
Facility: Length Of IE=0
Data
Progress Ind: Length Of IE=2
Data 8088
User-User: Length Of IE=157
Data
GWD-PSTN-NN-VPN-GW(config)#05280032C0060008914A00042800B500001240013C050100000A141F02E5F20000681AAA7974312102003102C0A8311C05800100010010A801003F0140B500001238600101000118311803A9838F1E0280881C269E8100036774640000001B4350472C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B4350472C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
*Aug 20 14:02:16.718: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8089
CRV Length             : 2
CRV Value              : 0x8002
Message Type           : 0x01: ALERTING
Data 8088
Signal: Length Of IE=1
Data 01
User-User: Length Of IE=152
Data
GWD-PSTN-NN-VPN-GW(config)#0523C0060008914A00042800B500001240013C050100000A141F02E5F21B0C00110000681AAA7974312102003102C0A8311C0100010010A801003A0140B50000123360010100011E2C1E0280881C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
*Aug 20 14:02:25.942: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8089
*Aug 20 14:02:25.942: %ISDN-6-CONNECT: Interface Serial0/1/0:14 is now connected to 89166047801 N/A
*Aug 20 14:02:25.946: %ISDN-6-CONNECT: Interface Serial0/1/0:14 is now connected to 89166047801 N/A
*Aug 20 14:02:25.946: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0089
As i can see there is both h323 and isdn alerting messages in this debug, but why there is no ringback tone?...
Also i have same h323 GW in another location (with almost same config), which is connected to CUCM to and i've ringback tone with this GW.
Can you help please...
Can you try adding the commands below to your outbound POTS dial-peers.
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
Please rate helpfull answers!
As you said that you have already followed the instructions as per your attachment but still i would suggest you to implement it once as per the Amine has suggested.
If still it doesn't work then please take one successfull debug of ring back tone along with the RTMT detailed trace and try to compare with the unsuccessful one.
Regards, Nishant Savalia
422
