Ringback tone with SIP trunk over CUCM
Hi Gens:
I am current have a big issue that I ever met before, then call process was from a 6921 ip phone through CUCM-- SIP Trunk-- GW to External Mobile phone.
The issue is, when call out to a Switched off mobile phone, the IP Phone can't hear the correct ringback tone either Busy Tone nor Service Provider's Ringtone, it hears normal Ringback tone same as when the mobile phone swithed on instead.
Has anyone met the same problem? I'd tested with different GWs all through SIP Trunk, but they all came with same result.
The configuration details as following:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
sip
  session transport tcp
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
voice-port 0/1/0:15
timeouts call-disconnect 1
timeouts wait-release 1
dial-peer voice 1000 pots
destination-pattern 9T
incoming called-number .
no digit-strip
direct-inward-dial
port 0/1/0:15
dial-peer voice 2001 voip
destination-pattern ^1...$
session protocol sipv2
session target ipv4:10.0.30.2
codec g711ulaw
no vad
dial-peer voice 2000 voip
session target ipv4:10.0.30.1
codec g711ulaw
no vad
dial-peer voice 3000 pots
translation-profile incoming plus9
dial-peer voice 5001 pots
destination-pattern 6..
port 0/1/0:15
dial-peer voice 2002 voip
dtmf-relay cisco-rtp h245-alphanumeric h245-signal rtp-nte
codec g711ulaw
no vad
Version 12.4
boot system flash c3825-ipvoicek9-mz.124-24.T6.bin
BTW, the call can be estabilished properly when calling anyone else, Please help to give some suggestion.
Highly appreciated for your help
Joe
1 ACCEPTED SOLUTION
Bronze
I fixed my issue. I had
I fixed my issue.
I had rel1xx turn on, on the trunk but turned off on the gateway which was stopping early media.
Is Early Offer configured for calls going out through this SIP trunk?
Manish
Hi  Manish:
it's delay offer configured for calls going out,
Joe...
Bronze
Hi , Did you ever get this
Hi , Did you ever get this sorted
I have a similar issue calling out via ISDN30 but using a SIP Trunk to talk to it.
I have tried
signal forward unconditional
voice call send alert
tone ringback alert-no-pi
It seems that the carrier automatically sends an alerting message.So I'm wandering whether this might be normal behaviour.
Bronze
I fixed my issue.
VIP Super Bronze
Great stuff Mark. Makes sense
Great stuff Mark. Makes sense since when the phone is switched off, it is early media that we should get..IE voicemail etc not ring back..This deserves our special VIP endorsement :)
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Bronze
You're too kind :-)
You're too kind :-)
VIP Super Bronze
Yes I have expereinced this too..Even when you call an external number and the user rejects the call, you hear a normal ringback tone over sip trunks..I think the issue is that the ITSP sends a 183 session progress or 180 ringing even before knowing what the state of the called device is..
You can send us a debug ccsip messages for a test call and we will be able to know exactly what is going on
Thanks aokaniawon, I will try to get the debug information, and post it later on as I am not on site at the moment. Thanks again.
Re: Ringback tone with SIP trunk over CUCM
Please check the debug details from GW and also RTMT tool. the mobile has been swtiched off, but the ring back tone from IP phone is just heard same as it's turned on.
Thanks for your help
Hi.
In the past hi had a similar issue with a mobile operator, I sovled this issue with tone ringback alert-no-pi in outgoing dial-peer configuration and voice call send-alert at global configuration level
Try it and resend a debug ccsip messages output.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Could you please configure 'signaling forward unconditional' under voice service voip and check how it works?
Please rate all the useful posts
//Suresh Please rate all the useful posts.
1521
