Ringing an IP Phone and Analog Phone at the same time
I have a VG224 and a 7912 IP Phone. I am running CCM4.1(3)sr1.
When I call he extension that resides on both phones, only the IP Phone rings.
The analog phone works fine, I can dial out on it.
1 REPLY
Re: Ringing an IP Phone and Analog Phone at the same time
Here are a couple of thoughts... If these don't work, can you send a screenshot of the Phone & VG Phone, and the Extension Configuration on each of the devices?
- Are the extensions showing as a "shared line", so we can verify that they are built in the same partition? What partition are they built in?
- What partition and calling search space are you making the test call from?
- If you remove the number from the 7912 does the analog phone ring when you call it?
--Joe
92
