RingList.xml / DistinctiveRingList.xml - why arn't phones using them?
davieshuw
Hi all.
I've copied a load of RAW files into the flash of my ccme 2801:
tftp-server flash:Classic1.raw
tftp-server Analog1.raw
tftp-server Analog2.raw
tftp-server AreYouThere.raw
tftp-server AreYouThereF.raw
tftp-server Bass.raw
tftp-server CallBack.raw
tftp-server Chime.raw
tftp-server Classic2.raw
tftp-server ClockShop.raw
tftp-server DistinctiveRingList.xml
tftp-server Drums1.raw
tftp-server Drums2.raw
tftp-server FilmScore.raw
tftp-server HarpSynth.raw
tftp-server Jamaica.raw
tftp-server KotoEffect.raw
tftp-server MusicBox.raw
tftp-server Piano1.raw
tftp-server Piano2.raw
tftp-server Pop.raw
tftp-server Pulse1.raw
tftp-server Ring1.raw
tftp-server Ring2.raw
tftp-server Ring3.raw
tftp-server Ring4.raw
tftp-server Ring5.raw
tftp-server Ring6.raw
tftp-server Ring7.raw
tftp-server RingList.xml
tftp-server Sax1.raw
tftp-server Sax2.raw
tftp-server Vibe.raw
And shared them out using the above commands.
I've edited ringlist and distinctiveringlist.xml files and put those in the root of flash too.
My CCME Admin guide pretty much says this is all I need to do. Reboot the phones and away I go.
However, on my 7941, I go into Settings, User Preferences, Rings, and only Chirp 1 is available. Where am I going wrong?
7 Replies 7
jburk
do you get the error File not Found:RINGLIST.XML after the phone boots? this will show on the phone display for a few seconds.
thisisshanky
Level 11
Level 11
Please do a create cnf-files and reset the phones.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Hey Sankar,
Nice to see you back my friend! +5 for this good tip.
Take care,
Rob
Hi guys, sorry I forgot to subscribe to this thread doh!
First thing I did was a create cnf files, and I dont get any error message appearing on phone bootup.. still all the same. Odd.. are the 7941's capable of supporting these ringtones?
Hey Rob, Thanks for the comments and the points..its been a while..feels good to be back.
Sankar Nair
bkvalentine
davieshuw,
It looks like you've forgotten the "flash:" part of the tftp-server command for every item that you want to serve via tftp.
For instance, say "tftp-server flash:RingList.xml".
Make that change for all of your tftp-server commands and then reboot the phones.
Matheus Lopes
Hi guys,
I got the same problem with IP Phone 7940 and i fixed this issue creating cnf-files and reseting the phone.
