Ringtones for CCM 3.3.5
Is there a place where I can download free ringtones for CCM 3.3.5 ?
Re: Ringtones for CCM 3.3.5
Here are a couple:
http://www.ccmstuff.net/
http://www.adman.net/cisco/ringtones/
Hope this helps. If so, please rate the post.
Brandon
I went and down loaded a ring tone and when I tried to access the ringtone.xml file I was not able to paste in the code for the ring tone. How are you able to add to the ringlist.xml file in CCM TFTP
I downloaded the flie to the TFTP Path in Call Manager. What I need to do it open the ringlist.xml file and be able to add to it with the
WalkThisWay
walkthisway.raw
to the current list which I am not able to do. As I said the walkthisway.raw file is in the TFTP Path directory.
I also stopped and started the TFTP Service within CCM Serviceability, and when I look at the list of ring tones in the phone the walkthisway is not listed and in the ringlist.xml it is not listed as well. I just need to be able to edit the ringlist.xml and stop the start the serviceability to make it happen.
Hall of Fame Super Red
Hi Bill,
Use an ASCII editor to edit the RingList.xml file.(I'm pretty sure I have used Notepad)Don't forget to save the original before making any changes :)
Hope this helps!
Rob
126
