12-17-2008 11:05 AM - edited 03-15-2019 03:08 PM
Is there a way to give users a wider selection of ringtones on lines 2 through 8? Currently Line 1 gets all the basic selections, but Lines 2 through 8 get only only static options labeled "Ring 1, Ring 2, Ring 3, etc".
Solved! Go to Solution.
12-17-2008 04:47 PM
Hi James.
This is most possible :)
From a super NetPro Jorge;
From BC;
The process is the same as it is to add a ringtone to the primary DN, only instead of editing the file "ringlist.xml", you edit "distinctiveringlist.xml".
Instructions located here: http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsrings.html.
Hope this helps! Happy Holidays!
Rob
12-17-2008 04:47 PM
Hi James.
From BC;
Rob
