rj-21 cable and distribution panel
Hi,guys,
I'm looking for vendors and part numbers of RJ-21 cable and distribution panel for VG224. I guess Cisco doesn't produce these gears?
Jonathan
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: rj-21 cable and distribution panel
Hi Jonathan,
You are most welcome my friend!
The Amphenol port on the VG224 is Female so you will need to order a Male RJ21. The RJ21 on the example Patch Panel is Male, so yes, a RJ21 Male to Female would be required :)
Hope this helps!
Rob
Hi Jonathan,
You have many options for cables and patch panels. Probably one for every situation that we can think of :) Here are the parts you would need to connect to a 24 port, rack mounted Patch Panel (without needing to terminate the cable with Bix or 110 connecting tools on terminating blocks). The Stonewall Cable website appears to be down today but is usually a great source. If you just Google "Cisco RJ21 Cables" you will get lots of hits :)
Cisco RJ21 Cables
http://www.stonewallcable.com/product.asp?dept%5Fid=102&pf%5Fid=SC%2D9754
24 Port with RJ21 Male
http://www.cablingsys.com/iteminfo.asp?productcode=017-224M62U
These are just examples :) I have not checked pricing $$
Hope this helps!
Rob
Hi, Rob, that helps a lot, thank you very much!
I've worked on VG224, but don't remember the details on wiring. According to Cisco website
http://www.cisco.com/en/US/docs/routers/access/vg224/hardware/installation/guide/higcabl.html#wp1006993
the RJ21 connector on VG224 looks Female?
Can you confirm if the flowing illustrates the connection right, if you happen to remember?
VG224(F) -> (M)RJ21 cable(F) -> (M)patch panel
Jonathan
Hi Jonathan,
Hope this helps!
Rob
Hi Rob.
We've got project with 2xVG224. Customer needs 40 analog fax machines to be connected.
I had been looking for rj21 cables and Telco panels to be connected via Male or Female but didn't find.
So we've done the other way. We've bought 2xrj21 male cables (with open ends) and 2xPatch panel (Cat. 3) with 25 ports each.
Then we took "rj21 color" table and "rj21 vs patch panel port numbers" table and stitched contacts with a special tool.
Then we've tested all the contacts from rj21 cable to rj45 contacts and pulled wires using cable ties.
All the pics and tables are in attached files.
P.S. Be careful to tie wires into holding places. Don't press too much (it could damage contacts between ports and holding places).
Hi Andriy,
Yes, looks very good my friend +5
Many people don't have the proper "punch-down" tools to accomplish
this, but your method is exactly the way it should be done if running
the 25 pair to a cross-connect or patch panel like the one you've used here.
Great job!
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Thx, Rob.
Yesterday Customer called me telling that port №16 on one of two panels doesn't work. I was surprised because at the moment of installation all ports worked normally. We tested them. So we came to site, tested port, it hadn't been worked.
TSHOOT:
We moved out panel cutting cabel ties and restitched contact to port №16 with a special tool. The port bacame working! We have moved it back on place and pulled RJ21 using cable ties like before.
Conclusion:
Contact pair of wires appropriating to port №16 have been displaced, losing the Rx/Tx ability.
KR
Andriy
8779
