RMON monitor Trunk Utilization on Cisco IOS Gateway
Justin Westover
I have a Cisco 2951 router acting as a gateway (H323) to call manager business edition. The 2951 routers has 3 PRI trunks that terminate into it and handle inbound and outbound calls. I would like to monitor the Call legs and set a threshold to send an snmp trap but i'm not sure what MIB object to use that would do this for me? So if i run a show call active voice, I can see the number of "Telephony call-legs" currently in session. Meaning I can see the number of active calls. I would just like to monitor that number and have an alert if I get close to around 50 active call-legs. But first I need the MIB that would allow this.
acampbell
JUstin,
May be better to ask this in the Network Management forum
https://supportforums.cisco.com/community/netpro/network-infrastructure/network-management
Alex
Regards, Alex. Please rate useful posts.
ronpatel
Level 8
Level 8
HI
You can see if this helps you
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.63.1.3.4#oidContent
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
