Showing results forĀ
Search instead forĀ
Did you mean:Ā
Roles & Permissions
juanmacipag
Gents,
I need your advice on how to do the following:
1. Prevent users from deleting a phone configuration  from CUCM.
2. Add and update new phones and assign VMs but MUST NOT be able to delete phone configuration
I have tried creating and tweaking test roles and assigning it to the test group i created but was unsuccessful:
Tested/Tweaked Roles: Standard CCM Phone Management, Standard CCM User Management, Standard CCM User Privilege Management
Platform: CUCM 8.6
Thanks!
Jaime Valencia
No way to do that on CUCM, either you can only see the config, and/or you can update it, and update means, add/delete/update, it's all or none.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
