Root or Tomcat credentials on Call Manager 5.1
Anyone know the default root or tomcat credentials for Call Manager 5.1? We're able to login to the CLI (admin: prompt) and it appears this interface is just a UNIX wraparound because any command spits out a similar UNIX output. My goal is to get in the Tomcat interface.
Re: Root or Tomcat credentials on Call Manager 5.1
Only TAC has this access. It is locked out for security and support reasons. (i'm only the messenger!)
When you call TAC, they can put in a security code for TAC access, then SSH to the console. They can login with some generated code they put in from the login in name, etc.
TAC only provides root access for Troubleshooting purposes (if necessary) or to apply the workaround for a bug
as the other thread mentions it's locked down for security purposes and only for the above conditions root access will be provided
java
if this helps, please rate
www.cisco.com/go/pdi
300
