I have a problem with a MCS7815-I2, when i start the CM5.1.2, I have acheck on the filesystem and then he ask to manual do a fsck, after that he comes with the message give root password for maintenance i have tried the passwords i know but without success, someone an idea ?
only TAC can provide root access pwd, you need to open a case.
java
if this helps, please rate
java
