Route calls based on extensions
Hi guys
First of all, I not have a good Englis so I hope you undertand me.
I would like to know if there is a way to route calls based on the caller id. This is, for instance, I have extensions 5xxx and 88xx and now they are going trough E1 0/0/1, I want to move this, and only this extension go out to pstn through teh E1 0/0/0. It is possible to do someting like this, in such case, how?
Best Regards
Everyone's tags (5)
Start by mentioning the product you're using and what protocol you use to integrate to the GW.
You do realize there's a spanish CSC?? right top corner, there's the language menu.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi.
You can also use the search function for your query because this topic has been touched many times here
Eg. Use caller ID route based as search keyword  and you'll find the solution
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
74
