Bronze
route calls from h323 gateway
im sure its a simple question and am seeing the answers here but just parts of it.
1. PRI gateway have a called number as 86862322xx. i want that to go to a pilot number 7000 (My auto Attendant).
2. i have DID numbers 821-59xx that id like to go to extensions.
whats the config?
rob
Re: route calls from h323 gateway
Voice Translation-rule 1
rule 1 /^86862322../ /7000/
rule 2 /^82159\(.*\)/ /59\1/
Voice Translation-profile DID-Incoming
translate called 1
voice-port 0/0/0:23
translation-profile incoming DID-Incoming
You will want to adjust the Voice Translation-Rule to reflect the proper digits that you are receiving from your carrier.
Bronze
that did it thanks.
my main numbers are working properly however with my DID numbers im geting out of service.
Note that this PRI just came up today.
rob
I'm glad it worked!
debug isdn q931
term monitor
should show what you are receiving from the carrier when you receive a call
Bronze
yeah i have been doing that but no luck. DID calls not coming in at all.
rob
Can you past the debug from an incoming DID call?
Bronze
there isnt any to collect
i have q931 and ccapi inout running with term mon and there isnt any activity with i call those numbers. again, everything is fine when i call my primary set of numbers and debugs are showing up as expected.
rob
Sounds like a carrier problem then, maybe they didn't finish the port.
Good luck!
Silver
test voice translation-rule 1 8215988
the result should show you 5988
Bronze
Results
Clf_VG#test voice translation-rule 2 8688215900
Matched with rule 2
Original number: 8688215900 Translated number: 1068
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
im translating the full number to go to extension 1068 for now.
181
