Community Member
Route calls to a determinated port based on the extension number
I'm trying to route the calls made by the extension 18 to a determinated port. For example if the extension 18 dial 0977xxxxx the call have to go to the port 3/1 and the if the extesions 1x dial 0977xxxx have to go to the port 3/0
Based on the cisco document
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con20
I made this config:
voice translation-rule 6
rule 1 /^0/ /77/
voice translation-profile prova2
translate called 6
dial-peer voice 5 pots
description Trucades Exterior
translation-profile outgoing 5
destination-pattern 0T
direct-inward-dial
port 3/0
dial-peer voice 6 pots
destination-pattern 77T
direct-inward-dial
port 3/1
dial-peer voice 567 voip
translation-profile incoming prova2
answer-address 18
when the extension 18 dial 0977xxx, the call goes out to the port 3/0.
As you can see on this document:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
answer-address have more priority than destination-pattern.
I tried to apply the translation-profile direct to the ephone-dn without success.
Gerard
Hall of Fame Super Gold
Re: Route calls to a determinated port based on the extension nu
Hi Gerard,
In fact you may have problems with translation-profile applied to ephone-dn, sometime these don't work.
And, DP voip with answer-address will never work, because the actual incoming DP is one automatically created by ephone-dn.
So, to associate an FXO port to an extension, use the command "trunk" in ephone-dn mode.
It is in the CCME command reference.
Community Member
The DP pots are over basic digital lines, seems that the "trunk" command on the ephone-dn its only for FXO ports.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611369.html#wp1094625
Is it correct?
regards
I'm afraid it is, you could try anyway.
On the other hand, which IOS are you using? The translation-profile method should work as well modulo any bug.
Community Member
The IOS version is 12.4(11)T. I will try the trunk command tomorrow and let you know.
Once you are there, please try also 12.4(11)XJ3 for translation-profile under ephone-dn. This release fixes many many bugs in telephony.
Bronze
Not too sure if this might help but i configured something like this for private lines on a T1. basically i did the same as above but in the route pattern i inserted the prefix as well.
therefore, when extension X dials a number it hits the route pattern with say 28 as the prefix and then matches the relevant DP with 28T (in my case) and then goes through that port. i also restricted it for that extension alone to use that port by using CSS and Partition to associate only with that extension
Hi A.
This is about CME, not CCM.
121
