Route Filter Troubleshooting
johnnylingo
Level 5
Level 5
I have a route filter that I'm trying to implement. The idea is for local calls, to allow 10 digit dialing as long as the area code is 206 or 425. The user can also use 7-digit dialing as well.
I've configured the route filter as (AREA-CODE == 206) or (AREA-CODE == 425), and applied this to the route pattern 9.1[2-9]XX[2-9]XXXXXX in the "LocalNumbers" partition. However, it seems to ignore the filter and the user can dial say 914087681234
I've tried using DNA to troubleshoot, and it does show it hitting that pattern in the correct partition but unfortunately I don't see the route filter information showing up.
Have I missed something here, or what's the best place to look? CCM 4.1(3)sr4b
John,
Route Filters only apply to patterns with the NANP @ in them. Here is the CCM 4.1(3) blurb on it.
Route filters, along with route patterns/hunt pilots, use dialed-digit strings to determine how a call is handled. Route filters only apply when you configure a pattern that contains the at (@) wildcard. When the route pattern/hunt pilot contains the @ wildcard, Cisco CallManager routes calls according to the numbering plan that is specified in the Numbering Plan drop-down list box. The route filter window that Cisco CallManager displays varies according to the numbering plan that you select.
Route filters allow you to determine which route patterns/hunt pilots your users can dial; for example, whether your users can manually choose a long-distance carrier (by dialing 101 plus a carrier access code).
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/b03rtflt.htm
Please rate any helpful posts
Fred
12 Replies 12
John,
Fred
You're absolutely right. When I changed the pattern to 9.@ it worked exactly as expected.
The only problem is now I get a timeout when doing local 7-digit dialing (9.[2-9]XXXXXX)
To get around that, I'd like to require users dial 9 + 1. However, changing the pattern to 9.1@ breaks the filter again.
Any ideas? Or are 7-digit dialers just stuck?
Hey Fred,
You really nailed that answer. Great work! 5 points from this end. Keep it up!
Take care,
Rob
Rob Huffman
Hi John,
This may sound nuts :) but it sounds like route pattern 9.1[2-9]XX[2-9]XXXXXX
Has "Route this pattern" checked instead of "Block this pattern".
Let us know,
Rob
mchandak
Level 7
Level 7
Instead of using the option Area Code, you should use Local Area Code along with a 9.@ Pattern.
You are correct about that, but above example I was using 91
ok. Since it mentioned, 10 digit dial I thought it was without the '1'. Anyways, looks like the issue was resolved by using @ Pattern :)
Yes, I should have said "11 digit dialing" since I was requiring a 1 in front. Sorry :)
miket
Level 5
Level 5
If you look in the callmanager SRND guide there are great examples of how to do exactly what you want.
http://cisco.com/go/srnd
When I do customer installs I always use 9.@ patterns with route filters. I've used this specific route filter for local 7 or 10 digit dialing.
(LONG-DISTANCE-OPERATIOR DOES-NOT-EXIST
AND INTERNATIONAL-ACCESS DOES-NOT-EXIST
AND TRANSIT-NETWORK-ESCAPE DOES-NOT-EXIST
AND LONG-DISTANCE-DIRECT-DIAL DOES NOT EXIST
AND AREA-CODE DOES-NOT-EXIST
AND LOCAL-AREA-CODE DOES-NOT-EXIST
AND OFFICE-CODE EXISTS
AND SUBSCRIBER EXISTS ) OR
(LOCAL-AREA-CODE == yyy)
* replace yyy with your specific area code
Of course you will have other 9.@ route patterns with route filters to specify 911, LD, and International dialing rules.
I find using route filters beneficial for a customer with multiple sites using a centralized call manager. I can re-use the same router filters applied to 9.@ patterns in different partitions.
Hope this helps.
Works great for 7 digit dialing and local area code + 7 digits, but what about 1 + local area code + 7 digits?
