Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Route Group Digit Manipulation on IP Phone
Dear All,
I added a prefix for outgoing calls through the gateway on the route group level to route calls through a particular FXO port.
Once the call gets connected to the gateway, the inlcuded prefix is appearing on the IP Phone. (very strange because the prefix is added at the route group level, not the route pattern).
Is their anything missing or need configurations to disable the display of this prefix on the IP Phone ?
The "alwasy display primary connected number" parameter has some limitations on forwarded calls, so I don't want to use it.
Thanks, Elie.
1 REPLY
Re: Route Group Digit Manipulation on IP Phone
Did you get an answer to this?
156
