Route Group for only for some port of H323 gateway
Hi, i need to select a couple voice port of H323 gateway and not all them.
Hall of Fame Super Gold
Re: Route Group for only for some port of H323 gateway
Please explain in better detail what problem you're trying to solve.
That config is not done in CUCM, in CUCM you only create an H323 GW which can contain 1 to N ports (CUCM is not aware of that)
The actual decision of which port to use is controlled by the pots dial-peers, so configure the dial-peers as necessary
java
if this helps, please rate
java
www.cisco.com/go/pdi
115
