Route Group
Hi There !
I have two routers... one is in the main office and has 3 E1 (qsig) and 1 E1 (R2) to PSTN...
I created a Route Group (and route list) for those E1(qsig) and another for the non-qsig interface... and it works fine..
ROUTE_GROUP_QSIG (PBX)
ROUTE_GROUP_NONQSIG (PSTN)
I also have a remote router with 1 E1(qsig - local PBX) and 1 E1 (R2) to pstn.. for this router I created a route list (and route list) for the non-qsig interface...
REMOTE_ROUTE_GROUP_NONQSIG (PSTN)
Now, I'm trying to create another route Group for the remote Qsig interface.. but it does not appear as an "Avaliable Devices" ...
CallManager 4.2
What is missing ?
Thanks.
Andrei.
1 ACCEPTED SOLUTION
Silver
Re: Route Group
Is the QSIG link you want to add assigned directly to a Route Pattern ? I`ve even had to delete the RG and add it again
Re: Route Group
are all the interfaces you're trying to use configured on CUCM?? because you say they're on a remote router and a PBX
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Route Group
yes, all interfaces are configured on CUCM 4.2(3)sr2b..
The QSIG interfaces are configurured with MGCP
The non-qsig interfaces are configured as an H323 gateway
Thanks.
Andrei.
Silver
Re: Route Group
I`ve came across this before, If I remember ocn eyo ahev allcoated a circuit to a Route Group it disappears from the "Available list" You have to assign the same RG to a new RL
Re: Route Group
no.. it did not work....
I created the now RL, then CUCM ask me to add a RG to this RL... but the list only show the non-qsig route group.
Thanks.
Andrei.
Silver
Re: Route Group
Re: Route Group
Great !
I removed all router patterns that used that interface.. and now it's working !
Thanks a lot.
Andrei.
308
