Route incoming call to extension
Currently I am using Cisco CISCO2901/K9 with 4 Voice FXO interfaces.
I would like to configure as below request.
Is it possible?
What configuration is need to achieve it?
Callers are given the option to enter an extension that routes the call directly to the internal user’s phone, or to be routed to a default location, such as an operator.
Current configuration : 16879 bytes
version 15.2
hostname Cisco_CME
boot-start-marker
boot-end-marker
logging buffered 51200
no aaa new-model
clock timezone GMT 8 0
ip dhcp excluded-address 10.53.4.1 10.53.4.10
ip dhcp pool IPPHONE_POOL
network 10.53.4.0 255.255.255.0
dns-server 10.53.4.2
default-router 10.53.4.2
option 150 ip 10.53.4.2
ip cef
no ipv6 cef
trunk group POTSTRUNK
trunk group POTSTRK
crypto pki trustpoint TP-self-signed-2913731135
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2913731135
revocation-check none
rsakeypair TP-self-signed-2913731135
crypto pki certificate chain TP-self-signed-2913731135
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393133 37333131 3335301E 170D3133 30323034 30343232
  32315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39313337
  33313133 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C8B8 A89478A0 8CE7456A 8AAA6EB7 16096839 49A19DF1 D6ABCB99 0C6E9134
  951497B5 94538B46 E1193EF4 B6A3B9E7 F3F48299 22B256DD 6D43E5F0 79E2C466
  AE742B15 E2F928DE 2166E885 17EBFB45 F36F628C F579BA86 09DBC177 18B50E28
  BF278246 722BB661 D9383AD8 49BE2CF2 AEA9FCD6 E1372878 EBEDFDE5 469E3E6B
  A1C50203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 141E3A7C 08DDD58E 33243B1D 3CDC300A 959677E7 DD301D06
  03551D0E 04160414 1E3A7C08 DDD58E33 243B1D3C DC300A95 9677E7DD 300D0609
  2A864886 F70D0101 05050003 81810045 31667A3E 9ADCE589 EC6A9756 EC63BA20
  2A5F6B01 71E14526 7A634355 D1B5C7C0 8F2D7602 45B54483 F4FBFBE3 A03F407B
  05264954 C18837E9 90072CB6 9AA40BAC 4A0FECB0 DCD17EEC 15BC2CBE 4C27372A
  E9048E75 E09AE0EA ED9B871C 487D8163 D7EA0F9D A87D5EAB B750AEF7 FAD8653A
  5993BF22 2638198C 6ACBE8B6 EF4365
            quit
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 10.53.4.2 port 5060
max-dn 200
max-pool 42
load 7942 SCCP42.9-2-1S
load 6921 SCCP69xx.9-2-1-0
authenticate register
authenticate realm abcd.local
timezone 41
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0324344033123261
voice register dn  1
number 1111
call-forward b2bua unregistered 11111111
allow watch
name 1111
label PolycomCon-110
voice register pool  1
id mac 0004.F2EA.1461
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username 1111 password 1111
codec g711ulaw
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
rule 5 /^/ /9/
voice translation-rule 2111
voice translation-rule 2112
rule 5 /^6/ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile INBOUND_TRANSLATION_PROFILE
translate calling 2001
translate called 2000
voice translation-profile OUTBOUND_NORWAY_TP
translate called 2112
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile OUTGOING_TRANSLATION_PROFILE_D9
translate calling 2111
license udi pid CISCO2901/K9 sn FGL1646215J
hw-module pvdm 0/0
username cisco privilege 15 password 0 cisco
redundancy
gw-accounting aaa
gw-accounting file
primary ifs flash:
acct-template callhistory-detail
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip virtual-reassembly in
interface Embedded-Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.53.5.2 255.255.255.0
interface GigabitEthernet0/0.10
encapsulation dot1Q 3
ip address 10.53.4.2 255.255.255.0
interface GigabitEthernet0/1
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.53.5.1
ip route 10.52.100.0 255.255.255.0 10.53.4.1
ip route 10.52.138.0 255.255.255.0 10.53.4.1
ip route 10.54.2.0 255.255.255.0 10.53.4.1
tftp-server flash0:apps42.9-2-1TH1-13.sbn alias apps42.9-2-1TH1-13.sdn
tftp-server flash0:cnu42.9-2-1TH1-13.sbn alias cnu42.9-2-1TH1-13.sdn
tftp-server flash0:cvm42sccp.9-2-1TH1-13.sbn alias cvm42sccp.9-2-1TH1-13.sdn
tftp-server flash0:dsp42.9-2-1TH1-13.sbn alias dsp42.9-2-1TH1-13.sdn
tftp-server flash0:jar42sccp.9-2-1TH1-13.sbn alias jar42sccp.9-2-1TH1-13.sdn
tftp-server flash0:term42.default.loads alias term42.default.loads
tftp-server flash0:term62.default.loads alias term62.default.loads
control-plane
voice-port 0/0/0
trunk-group POTSTRK
supervisory disconnect dualtone mid-call
no battery-reversal
echo-cancel erl worst-case 0
echo-cancel mode 2
cptone MY
timeouts call-disconnect 3
timeouts ringing infinity
timeouts wait-release 3
connection plar 200
description FXS
caller-id enable
voice-port 0/0/1
trunk-group POTSTRK
no battery-reversal
echo-cancel mode 2
cptone MY
connection plar 107
description FXS
voice-port 0/0/2
trunk-group POTSTRUNK
no battery-reversal
echo-cancel mode 2
cptone MY
connection plar 200
description FXS
voice-port 0/0/3
no battery-reversal
echo-cancel mode 2
cptone MY
connection plar 200
description FXS
mgcp fax t38 ecm
mgcp profile default
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 54 pots
trunkgroup POTSTRK
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9.T
no sip-register
dial-peer voice 104 pots
description "Incoming Call to DN"
translation-profile incoming INBOUND_TRANSLATION_PROFILE
destination-pattern 1...
incoming called-number .%
direct-inward-dial
port 0/0/0
dial-peer voice 2000 voip
destination-pattern 8..
session protocol sipv2
session target ipv4:10.52.138.41
codec g711ulaw
dial-peer voice 105 pots
direct-inward-dial
port 0/0/1
dial-peer voice 106 pots
direct-inward-dial
port 0/0/2
dial-peer voice 107 pots
direct-inward-dial
port 0/0/3
dial-peer voice 220 pots
trunkgroup POTSTRK
description ** Mobile No. (7-digits) **
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
destination-pattern 901[0,2-9].......
dial-peer voice 200 pots
trunkgroup POTSTRK
description ** Outstation No. **
destination-pattern 90[2,4-7,9]T
direct-inward-dial
dial-peer voice 210 pots
trunkgroup POTSTRK
description ** Sabah/Sarawak **
destination-pattern 908[2-9]T
direct-inward-dial
dial-peer voice 230 pots
trunkgroup POTSTRK
description ** Mobile No. (8-digits) **
destination-pattern 9011........
direct-inward-dial
dial-peer voice 240 pots
trunkgroup POTSTRK
description ** Toll-Free **
destination-pattern 91[3,6,8]00......
direct-inward-dial
dial-peer voice 250 pots
trunkgroup POTSTRK
description ** IDD to Singapore **
destination-pattern 90065[0,1-9].......
direct-inward-dial
dial-peer voice 260 pots
trunkgroup POTSTRK
description ** IDD to the rests **
preference 7
destination-pattern 900T
direct-inward-dial
dial-peer voice 270 pots
trunkgroup POTSTRK
description ** Local No. **
destination-pattern 9[2-9].......
direct-inward-dial
dial-peer voice 313 pots
trunkgroup POTSTRUNK
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE_D9
destination-pattern 69[2-9].......
direct-inward-dial
dial-peer voice 306 pots
destination-pattern 6901[0,2-9].......
dial-peer voice 307 pots
destination-pattern 690[2,4-7,9]T
direct-inward-dial
dial-peer voice 308 pots
destination-pattern 6908[2-9]T
direct-inward-dial
dial-peer voice 310 pots
destination-pattern 691[3,6,8]00......
direct-inward-dial
dial-peer voice 311 pots
destination-pattern 690065[0,1-9].......
direct-inward-dial
dial-peer voice 312 pots
preference 7
destination-pattern 6900T
direct-inward-dial
dial-peer voice 2001 voip
destination-pattern 7..
session target ipv4:10.54.2.2
codec g711ulaw
gatekeeper
shutdown
telephony-service
max-ephones 40
max-dn 40
ip source-address 10.53.4.2 port 2000
auto assign 1 to 40
service phone ehookEnable 1
service directed-pickup gpickup
service dnis dir-lookup
timeouts interdigit 4
cnf-file location flash:
time-zone 43
date-format dd-mm-yy
max-conferences 8 gain -6
moh "flash:/music-on-hold.au"
transfer-system full-consult
directory entry 1 100 name Aniza
directory entry 2 101 name Kumar
directory entry 3 102 name Desk-Phone
directory entry 4 103 name Raj
directory entry 5 104 name 5
directory entry 6 105 name Daniel
directory entry 7 106 name Anderson
directory entry 8 107 name Bala
directory entry 9 108 name Jessica
directory entry 10 115 name Staff 1
directory entry 11 116 name Staff 2
directory entry 12 117 name Staff 3
directory entry 13 118 name Staff 4
directory entry 14 119 name Staff 5
directory entry 15 120 name Staff 6
directory entry 16 321 name IT Service Desk
create cnf-files version-stamp 7960 Oct 04 2013 12:20:49
ephone-dn-template  1
ephone-template  1
softkeys idle  Redial Newcall Cfwdall Gpickup Dnd
softkeys connected  Hold Endcall Trnsfer Park Confrn ConfList
ephone-dn  1
number 100
pickup-call any-group
pickup-group 1
label Aniza
name Aniza
ephone-dn  2
number 101
pickup-group 1
label Kumar
name Kumar
ephone-dn  3
number 102
pickup-group 1
ephone-dn  4
number 103
pickup-group 1
label Raj
name Raj
ephone-dn  5
number 104
pickup-group 1
ephone-dn  6
number 105
pickup-group 1
label Daniel
name Daniel
ephone-dn  7
number 106
pickup-group 1
label Anderson
name Anderson
ephone-dn  8
number 107
pickup-group 1
label Bala
name Bala
ephone-dn  9
number 116
pickup-group 1
label Staff 4
name Staff 4
ephone-dn  10
number 109
ephone-dn  11
number 111
ephone-dn  12
number 321
description IT ServiceDesk
call-forward all 90048717608503
ephone-dn  15
number 115
pickup-group 1
label Staff 1
name Staff 1
ephone-dn  16
number 108
pickup-group 1
label Jessica
name Jessica
ephone-dn  17
number 117
pickup-group 1
label Staff 3
name Staff 3
ephone-dn  18
number 118
pickup-group 1
label Staff 4
name Staff 4
ephone-dn  19
number 119
pickup-group 1
label Staff 5
name Staff 5
ephone-dn  20
number 120
pickup-group 1
label Staff 6
name Staff 6
ephone-dn  39
number 188 no-reg primary
park-slot directed timeout 60 limit 2 transfer 100
name ParkSlot
ephone  1
mac-address 1833.9D15.43C2
ephone-template 1
type 7942
button  1:8
ephone  2
mac-address 1CE6.C799.7E7E
ephone-template 1
fastdial 1 0193309984 name Ken
fastdial 2 0137837783 name Gabriel
type 6921
button  1:3
ephone  3
mac-address 1CE6.C799.7EF9
ephone-template 1
type 6921
button  1:4
ephone  4
mac-address 1CE6.C799.3F86
ephone-template 1
type 6921
button  1:2
ephone  5
mac-address 1CE6.C799.7E43
ephone-template 1
type 6921
button  1:5
ephone  6
mac-address 10BD.1800.7793
ephone-template 1
type 7942
button  1:7
ephone  7
mac-address 1CE6.C799.83C2
ephone-template 1
type 6921
button  1:1
ephone  8
mac-address 10BD.1800.7807
ephone-template 1
fastdial 1 9087442905 name offshore
type 7942
button  1:9
ephone  9
ephone  15
mac-address 44AD.D9D4.0A96
ephone-template 1
speed-dial 1 690128802017 label "wan"
speed-dial 2 690129545350 label "Iris"
speed-dial 3 690128599381 label "Irrvin"
speed-dial 4 690135975705 label "Sam"
type 7965
button  1:15
ephone  16
mac-address 44AD.D9D4.1717
ephone-template 1
speed-dial 1 9087519905 label "lab"
speed-dial 2 690062554412867 label "Ke"
speed-dial 3 90128599381 label "Irrvin"
speed-dial 4 90183322123 label "Zen"
type 7965
button  1:16
ephone  17
mac-address 44AD.D9D4.1746
ephone-template 1
type 7965
button  1:17
ephone  18
mac-address E8ED.F3AB.0CEC
ephone-template 1
type 7965
button  1:18
ephone  19
mac-address E8ED.F3AB.0BD6
ephone-template 1
type 7965
button  1:19
ephone  20
mac-address E8ED.F3AB.0EBC
ephone-template 1
type 7965
button  1:20
ephone-hunt 1 sequential
pilot 200
list 102, 101, 100, 120
final 102
timeout 20, 20, 10, 10
statistics collect
present-call onhook-phone
ephone-hunt 2 sequential
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login local
transport input all
line vty 5 15
login
transport input all
scheduler allocate 20000 1000
ntp server 120.100.97.148 prefer
end
Cisco_CME#
I think you need B-ACD and AA for that ...
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl/40bacd.html
Go though this link and change it accroding to your requirement.
Manish
You can do the AA on CUE.
voice-port 0/0/0
connection plar 820952 !(AA Extension on CUE)
caller-id enable
dial-peer voice 820952 voip (!Dial peer to CUE)
destination-pattern 820952
session target ipv4:172.28.85.2
Then configure your CUE which will be a mailbox of 820952 like in my example. You can then record prompts and have it transfer to extensions from Unity.
Does it mean that I have to buy additional module to support it?
Hi Kevin,
You can go through the link that Manish Prasad share.
You can build Auto Attendant like the request on CME using TCL script (the script is provided by Cisco and you can download form cisco.com)
You don't need any additional module to support it, just follow the config guide.
Rgds
Novri
217
