Community Member
Route List 4.2(1)sr1b
I have configured a route list with 2 route-groups, than i assign a route-pattern to that route-list. Afther some time I decided to remove the 2 route group form the route list, and reset the r-list, but the for same reason the callmanager is sending the traffic to thath route-goup, I have tryed to reset the route-list but with no success.
From the buug-tool-kit i did not find any related bug.
1 REPLY
Green
Re: Route List 4.2(1)sr1b
Ok you create RG1 and RG2.
You assigned those to RL.
RL - RG1,RG2
You remove RG2. Reset the RL
But after this calls are being still routed to
RG2 using the same RL ?
Please try to recreate the RL again, provide CCM|SDL detailed trace during the reset and while calling.
If you can you can reset ccm.exe but this wont let us know the root cause.
101
