Route List/Route Group CCM 702
I am having a problem with route lists in CCM 702. I have 1 route list with 2 route groups in it. Each RG has 1 Voice Gateway in it. My problem is when my Primary PRI circuit goes down on the Primary Voice Gateway, calls fail to re route over the backup Voice gateway Bri Lines. If I disconnect the ethernet interface on the Primary VG, calls re route over the backup VG as expected. I have tried a number of IOS releases. Has anyone come across this issue. IS it a CCM 7 bug possibly?
Re: Route List/Route Group CCM 702
most important, what protocol are u using on the GWs???
java
if this helps, please rate
java
www.cisco.com/go/pdi
we are using h323. Sorry I should have mentioned that ealier
change this parameters and try again
Clusterwide Parameters (Route Plan)
Stop Routing on Unallocated Number Flag = False
Stop Routing on User Busy Flag = Flag
java
java
I've the same issue with H.323 and CUCM 7.0.2 but setting the service parameters doesn't solve it.
Thank in advance.
Stefano
any luck getting this resolved. running into same issue. service parameters are set correctly.
Derek
if the service parameters do not work try add the command
no dial-peer outbound status-check pots
to the outbound peer on the H323 gateway.
This will send a temporary failure message instead of unallocated number which will allow the RL to continue to hunt.
Brian
471
