Route Pattern Block Reason
I am trying to find documentation on the drop down box for block reason on a route pattern, does this show in logs somewhere because it doesn't seem to show on the phone when the call is blocked.
Thanks.
1 ACCEPTED SOLUTION
Re: Route Pattern Block Reason
only shows on CUCM trace
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
VIP Super Bronze
and on the phone's display to tell the user why their call was not routed.
I have not seen it show up on the phone, you just get a fast busy.
and that's the right behavior, users do not get any kind of message or notification the call cannot be made due to restrictions.
the moment you match a pattern with block this pattern there is no further action other than sending the phone reorder.
java
java
234
