02-28-2014 04:43 PM - edited 03-16-2019 09:58 PM
I have a all route pattern with a discard digit "9" and the national calling starting from "2" and GSM from "9",
i hear a outside dialtone whenever i press a second digit "9" or digit "2", is it possible to get the outside dial on pressing first digit whcih is discard digit "9"
I think it is not possible but i want to confirm from youll experts,
02-28-2014 07:06 PM
Your explanation is not clear at all, short answer is
To get the secondary dial tone right after the first 9, there cannot be absolutely anything else in your dial plan (which is not a route pattern with provide secondary dial tone checked) configured
If you don't hear it, two options
A) overlapping
B) assuming no overlapping, a RP is missing the checkbox for secondary dial tone.
This topic has beed discussed hundreds of times before, please search for answers before posting.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-28-2014 10:11 PM
Yes Jaime,
It is not understandable, i will make it more clear.
Below are the route pattern in CUCM.
9.2XXXXXXX
9.9XXXXXXX
9.1XXX
9.9999
Customer is asking that why i am hearing a outside dial tone only after pressing a second digit such as 2,9,1, according to the above route pattern, but what he wants is that outside dialtone should come on pressing first digit "9" which is discard digit.
I think is not possible, to get the outside dial tone on pressing first button if i want to acheive than i think i have to change the dial plan by removing the discrad digits,, Please confirm to me that i am correct. ??????
02-28-2014 11:09 PM
No, your understanding is completely wrong, the fact that you have discard predot has nothing to do with that behavior.
If you dont hear it right away, it means theres something else in your dial plan that overlaps, or, youre missing the secondary dial tone in a RP.
02-28-2014 11:51 PM
03-01-2014 06:58 AM
Dial plan means EVERYTHING in CUCM, not just RPs, check your dial plan for overlapping.
java
03-01-2014 07:06 AM
Dear Jaime,
Need more hints where things i should check,, Ur help will be appreciated.
03-01-2014 07:47 AM
Hello Clark,
The secondary dial tone function can be enabled on route patterns and translation patterns. The dial tone will change only if all possibly matching route or translation patterns have the secondary dial tone enabled.
Search your Translation & Route Patterns with the criteria 'begins with 9' and make sure 'Provide Outside Dial Tone' is checked for all those patterns that begins with 9
//Suresh
Please rate all the useful posts.
03-01-2014 08:42 AM
Dear Suresh,
I dont have any translation profiles only the attached route pattern as per the previous reply and all are enabled with provide outside dial tone.
03-01-2014 09:15 AM
There are no hints, you really need to check EVERYTHING. DNs, meetme, call park, anything that has a pattern/DN configured. Use the route plan report.
And Suresh is falling in one of the most common mistakes when this happens, "it must be something with 9..."/"it must be a RP/TP", sometimes it might be, many other it won't.
You need to check for ANYTHING that has wildcards that might match 9, as well as anything that start with 9. And not limit yourself to just RPs and TPs.
I can tell you back when I was in TAC, as soon as I asked them if they had configured anything else other than a RP/TP with 9, they often said "Oh yeah, I added a DN/CTI/meet-me, etc with 9, could that be the issue??"
java
03-01-2014 09:36 AM
Clark,
Overlapping pattern can also exist in the none partition.
Start by checking under Call Routing -> Route Plan Report for any patterns which might start with !, @, or [ .
If nothing there, try this SQL query:
run sql select fkroutepartition, dnorpattern, outsidedialtone from numplan where dnorpattern like '9%' and outsidedialtone = 'f'
Gagarin
