route pattern export to excel
I would like to ask whether there is any way to export route pattern to excel without using Route Plan Report? It is because I would like to collect the setting of each route pattern.
Gold
Re: route pattern export to excel
Can you please explain as to why this would not work for you ?? NumPlan report is the only export utility available with CCM
actually, i would like to collect the properties of each route pattern and put them into Excel for reference. the excel contains route pattern, partition, gateway list, route option, call classification, calling party transformation, connected party transformation, called party transformation.
518
