route pattern for internal dialing
All,
Need your help. The CM adin left the company and I will have to take it over.
I just checked the route patterns, they all start with 9.@ or 9.011 or 9.1[2-9]xx[2-9].....there seemed no route patterns for internal dialing. What is I want to dial a 4 digit internal number such as 1234, how will that call be routed?
1 ACCEPTED SOLUTION
Re: route pattern for internal dialing
You do not need route patterns for internal dialing. Callmanager knows about internally assigned DNs and allows calls to/from these extensions based on calling search spaces and partitions. The calling phone must have a calling search space which contains the partition of the called phone in order for the call to complete.
Hope this helps.
Brandon
1 REPLY
Hope this helps.
Brandon
213
