Route Pattern with time based
Is there a method to configure RP (Route pattern ) to block any  calls outside working hours ?
I am using CUCM 8.6
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Route Pattern with time based
Yes sure you can use RP to block calls based on time of the day. You will need to use Time of day routing to do this..
The link above shows how to configure time of day routing..
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
Once you have created your time periods and schedule, assign time schedules to partition and assign partition to RP.
You then create two RP as follows
RP1, in pt-OOH
under route option, you selct block this pattern
RP2, in pt-OH
select route pattern
Please rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 REPLY
VIP Super Bronze
RP1, in pt-OOH
RP2, in pt-OH
342
