Community Member
\+! route pattern
Please light me how to use + route pattern, when ever I am trying + route pattern, the lady says your call cannot be completed as dial, so my client not able to dial the missed International call directly.
I have check the + route pattern without partiton also.
Please correct me what I am missing in + route pattern.
1 ACCEPTED SOLUTION
Bronze
Re: \+! route pattern
also, one more update
CIPC 7.O E.164 "+" is NOT supported
Bronze
use 9.011! route pattern,
you need to uncheck the urgent priority for this particular route pattern,
There is an option in callmanager administration-->Service-->Service
parameters--> lick on advance button and then search for national number
prefix (add 91), international number prefix (add 9011), subscriber number
prefix (add 9), unknown number prefix( add 9)
Community Member
Yes I am using 9.011 pattern to, my question is if I am finding +1408 route pattern as missed call, how to dial that missed call pattern without edit that missed call number, when I am trying + route pattern, I am getting a lady voice your call cannot be completed....
Please light me on + route pattern
Bronze
Hi there,
a route pattern \+! that has a called party transformation to strip the + and apply the external access and applicable international access code should do it.
regards,
Paul
Bronze
Did you try this,
you need to uncheck the urgent priority for that route pattern,
Bronze
Community Member
the natinal, international and subscriber in Service parameter coming with options phone, MGCP gateway and H.323 gateway, should I update the calling number prefix in all the steps, please light me about the prefix number.
528
