Community Member
Route Pattern
I have a route pattern for mobile numbers
9.07XXXXXXXXX
I also have a route pattern that allows the caller to prefix 141(to hide CLI)
9.14107XXXXXXXXX
Is there a route pattern configuration that will allow for the 141 prefix to be added or not to be added instead of having to add two route individual patterns?
1 REPLY
Silver
Re: Route Pattern
ajames
IMO there should not be any issue with adding both patterns. Remember you will route the 141 to PSTN or mobile network which will then hide the callerID. Therefore you should add both to satisfy the requirement.
The other thing which is good to know, is that PSTN or mobile networks are expecting a certain number of digits in the callerID. So, if you prefix that with say any 5digits - I have seen the number come up as unknown. This one method to achieve callerID masking by yourself instead of relying on public phone networks.
I am struggling to think of any way you could merge two route patterns into one. Anyway two are better than one ;)
2cents
Ajaz
331
