Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Route Patterns for 911 and DID
We have route patterns configured for 911 in our CUCM cluster, 6.0.1. When you dial 9.911 it uses a Route List and Route Group and routes the 911 call out the local POTS line on the remote MGCP Gateway instead of the central sites PRI. My question is since the call gets routed out the local POTS line, the caller ID is showing information for that line. Does anyone have any suggestions on how to configure DID on the POTS line so they get routed to a person? Right now when you call those POTS lines you get an unreachable message.
1 ACCEPTED SOLUTION
Re: Route Patterns for 911 and DID
You have a couple options, but missing some information.
The problem is that POTs line are probably FXO lines. meaning they are "Office" lines outbound only for backup.  No inbound with the FXO lines.
If you need this type of call back, probably need to have FXS in the mix also and CER server.     The problem is, there is no dynamic way to know who called 911 when the call comes back in.  CER handles this with its own database of when/where, etc.
Example:
phone dials 911   x4000
CUCM sends the call to CER
CER masks the call with a zone and callback number
CER sends the call back to CUCM
CUCM sends the call outbound through the FXO lines with the caller ID of the PRI for call back.
911 dispatch answers
call gets disconnected
911 dispatch redials the caller ID number
It comes in through the PRI
CUCM intercepts, sends the call to CER
CER reads the calling number, matches who called from that zone and sends the call back to CUCM for x4000
call is reconnected
Example:
call is reconnected
We use FXO line and set up the connection plar on the voice port to ring to a main number if someone calls back in the POTs list
voice-port 0/3/0
connection plar opx  (4 digits of the main number)
description POTS  (10 diget number)
caller -id enable
Thanks for the suggestion!
1135
