Route Plan
Does anyone know of a way to get your route plan report into a more user friendly interface (instead of excel)?
1 REPLY
Re: Route Plan
Yes, you can use SQL query to create customized query to pull reports - first of all you need to understand CCM DB schema and its tables fields, then build your own SQL query script for your own report, like: RP/Partition/CSS/Translated-Mask/GW...
Pls rate if help
116
