Community Member
Route straight to System Directory Handler
Hi. Im trying to figure out how to route calls directly from a user calling an extension to a System Directory Handler.  eg: user calls dn -> directory handler answers -> the user can search the directory for other users.
I dont want voicemail or a call handler.  Is this possible?  How exactly is it done if possible.  Ive tried different setups and nothings worked the way i want.
Im using Call Manager 8.6 and Unity Messaging 8.6.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Use call routing rules to do
Use call routing rules to do that.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Community Member
Still having issues with
Still having issues with calls going straight to the DN's voicemail.
eg:
New User DN = 1234 w/ mailbox
Created a Direct Routing rule with the following attributes:
-Dialed number = 1234
-Active rule
-Send call to AD
-ln order of Precedence new rule is listed before other Direct Routing Rules
When I call 1234 it still goes to the generated voicemail box.  What am I missing?  Is it somehow not matching 1234 when calling in?
Community Member
Figured it out.  It works as
Figured it out.  It works as a Forwarded Routing Rule instead of a Direct Routing Rule.  Doesnt make sense but whatever.
42
