02-21-2008 05:47 AM - edited 03-15-2019 08:59 AM
Hey all,
I would like to route a call coming in by CLI rather than destination-pattern. So instead of saying if the destination-pattern is x send to this trunkgroup I'd like to do that based on CLI instead.
Is that possible?
Anthony
Solved! Go to Solution.
02-21-2008 06:32 AM
Anthony,
Take a look at the following link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
Hope this helps. If so, please rate the post.
Brandon
02-21-2008 06:32 AM
Anthony,
Brandon
02-21-2008 07:38 AM
Hi Brandon,
I tried using the answer-address command but it doesn't seem to work. Should the answer-address be the same as the SIP 'Calling Number'? That's what I'm trying.
Anthony
02-21-2008 08:27 AM
Yes, I believe so. If you turn on "debug voip dial peer" and make the call, do you see the call hitting the dial peer? What is the calling number?
Brandon
02-21-2008 11:20 AM
Sorted!
It's the other way around for me, I'm going from VoIP to POTS and you have to do that translation stuff that your doc talks of.
Thanks for the help.
Anthony
