Route via Caller-ID CLI
anthony.baker
Hey all,
I would like to route a call coming in by CLI rather than destination-pattern. So instead of saying if the destination-pattern is x send to this trunkgroup I'd like to do that based on CLI instead.
Is that possible?
Anthony
Brandon Buffin
Anthony,
Take a look at the following link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin
Anthony,
Brandon
Hi Brandon,
I tried using the answer-address command but it doesn't seem to work. Should the answer-address be the same as the SIP 'Calling Number'? That's what I'm trying.
Anthony
Yes, I believe so. If you turn on "debug voip dial peer" and make the call, do you see the call hitting the dial peer? What is the calling number?
Brandon
Sorted!
It's the other way around for me, I'm going from VoIP to POTS and you have to do that translation stuff that your doc talks of.
Thanks for the help.
Anthony
