Router 2801 Max dialpeer
dlignier
I have a 2801 who use for QSIG with PABX Matra.
This router is in H323 not MGCP, and i must configure on this router a lot of dialpeer voip (50).
I don't find a document in which i find limitations of number dialpeer for this router.
thanks for your help.
Sébastien
Joel Hatfield
Check and see if this helps you:
https://supportforums.cisco.com/docs/DOC-3206
"This formula calculates the  available dial-peer options:
(Free Memory *  0.8)/6k = maximum theoretical number of configurable dial-peers
This number represents the  upper limit."
