Router 2911 - FXS problem - IPphones
Hi everybody,
I’ve a problem with my FXS config. I’ve a 2911 router and I want to connect two fax .
This my current config:
voice-port 0/2/0
     timeouts interdigit 5
     description FXS PORT 0
     caller-id enable
voice-port 0/2/1
      description FXS PORT 1
      caller-id enable
dial-peer voice 1 pots
      destination-pattern 219
      port 0/2/0
dial-peer voice 2 pots
      destination-pattern 220
      port 0/2/1
My question is, why I don’t receive the caller-id on my fax/phone. I’ve an other problem, I haven’t the end tone (the tone that we can hear when a phone ring off). I’ve the same problem on my IP Phones.
Can you help me please ?
Kirk
Everyone's tags (5)
No idea ?
Could you help me please
Re: Router 2911 - FXS problem - IPphones
add
answer-address 219
and
answer-address 220
on the applicable ports.
Edit: Good Lord my answer has absolutely nothing to do with your question. I am not sure what I thought I read. I was working on some paging while posting and must have confused the two.
Anyway.........what are the incoming numbers coming in on? FXO ports or a PRI?
Thanks for your reply.
You want to know what is the phone number displayed?
I haven't FXO ports so i think it's PRI but i'm not sure about this
Kirk.
EDIT: For the dialtone when a phone hangs up, the command for the fxs port is "tone dialtone remote-onhook". This command is on default setting and i haven't again this dialtone. What is the problem? (My ipphones have the same problem...Why?)
        Is it possible to define the same phone number on two FXS ports?
issue the command "show isdn status", what do you get?
Sorry for this late
it doesn't work!
IOS 15.1 (this command is not recognized)
Please, help me!
I just want to know how to enable the end-tone on my voip phones and pstn phones. This is the only thing that i want to know today because the other are optionnal.
Kirk
Hi;
Try applying:
cptone (followed by country code i.e. GB for the UK) to the analogue voice ports.
As for the IP Phones if you post the e-phone and ephone-dn configurations I may be able to assist there also.
Hope this works for you I have this set on my FXS port.
1299
