Router and CUCM Gateway
Hi all
Please help with the left side of the figure
What do I need to configure routers (1 and 2) to ensure that the calls would come and go from and to the router 3
and in general need to do something between the two routers?
Please see attach
1 ACCEPTED SOLUTION
Yeah, you are right.Here both the gateways act on its own.No relations between them.
Siva
Pls rate if helps you.
Well, it depends.What gateway (h323 or mgcp or Cube) you would like to configure.How abt connectivity to R3 ? meaning is it a sip trunk ?
Can you pls put in detail ?
Siva
Re: Router and CUCM Gateway
i connect CUCM8.6 with gateway (R2) with mgcp and configure E1 port
R3 is a GateKeeper and i want to send with H.225 GK controlled trunk
You can go like this..
CUCM > MGCP > E1 - for calling PSTN calls.
CUCM > R3(Gatekeeper) - for calling other offices.
Use different route patterns pointing to MGCP gateway and GK.
Siva
Thanks for help, but I have not had this in view
I wanted to ask, do I have something set up between the R1 and R2?
or call automatically will be held at R1 and get the R2 and vice versa ?
As you've pointed out above (CUCM> R3 (Gatekeeper) - for calling other offices.) I understand that there are no options needs betweens R1 and R2.
Am I right?
Siva
283
