Router E1 log
Hi, when I enter the command "pri-group timeslots 1-31" under the second controller in the Router, this messages is showed:
Router3800(config)#controller E1 0/0/1
Router3800(config-controller)# pri-group timeslots 1-31
% Not enough DSP resources available to configure pri-group on controller E1 0/0/1
% The remaining dsp resources are enough for 26 time slots.
% For current codec complexity, 1 extra dsp(s) are required to create this voice port.
How I can resolve the problem ?
1 REPLY
Re: Router E1 log
Have you confirmed you DO have enough DSPs free on the router or module where the card is to use it????
The message says that you only have 26 channels available for use.
If you indeed only have 26 channels the options are to only enable the 26 channels or add DSPs
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
230
