Router Upgrade
I am in the process of planning an router upgrade running CCME/CUE AIM.  I am currently running 12.3(11)T11 CME3.2/CUE2.1.3 IPVOICE feature pack and would like to upgrade to 12.4(15)T with the latest version of CME and CUE available for that ios version.
If there is a later version of the IOS,CME,CUE that will run on my router I would like that.  Basically want to updgrade to the newest version that will run on my router.
We are also installing a new 1GB AIM module to the router.  It currently has an AIM-CUE in it. The router is a 2651XM.
I need to find a good upgrade guide that will quide me through the upgrad process.  I have been unable to find one on cisco.com.
Also, please advise me to the latest version that will run on my router.
Attached is a sh ver, and sh diag
Everyone's tags (4)
1 REPLY
Super Bronze
Re: Router Upgrade
See this link for a mapping of IOS to CME versions:
http://www9.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Click on the links to the right and scroll to the bottom to see which platforms are supported - 2651xm isn't supported for some newer versions.
When you decide which version to upgrade to, check your CUE compatibility to determine which versions you can/should run, and whether you need to upgrade Unity first:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Upgrading CME is basically a matter of upgrading your  IOS, and upgrading firmware and GUI files in accordance with what's listed on the links above. There should be a bundle download zip that includes all the GUI and firmware files.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
519
