03-25-2009 01:34 PM - edited 03-15-2019 05:05 PM
hi,
I have cisco router 2811,with 4ports POE and i have to use this 4ports POE as switch so how can i use it and if we need config what i have to config.
03-25-2009 01:58 PM
Hi there!
So you have an Etherswitch module on your 2800 (HWIC-4ESW-POE or HWIC-D-9ESW-POE)?
I'm including a link with a config example, this can give you an overview of what you need to config:
HTH, if it does, please rate.
Teresa.
03-25-2009 02:14 PM
thanks for ur quick reply..
