Router with 4Ports POE
shamkumar
hi,
I have cisco router 2811,with 4ports POE and i have to use this 4ports POE as switch so how can i use it and if we need config what i have to config.
testeven
Hi there!
So you have an Etherswitch module on your 2800 (HWIC-4ESW-POE or HWIC-D-9ESW-POE)?
I'm including a link with a config example, this can give you an overview of what you need to config:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a0080810449.shtml
HTH, if it does, please rate.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
thanks for ur quick reply..
