Routing incoming calls from outside
Hello everyone. I am new at Cisco VOIP and i need some help.
I manage to create VoIP on my router C2911 and i have 3 IP phones. I have one voice port that is conected to my country telecom(ground line whose number iz YYYYYY). My phones have 3 digits extensions. Example 222, 333 and 444. They can call each other localy. I configured dial peer pots, and when i make call from my IP phone to my cell phone(number of cell phone: xxxxxxx) it goes through voice port, and on my cell phone is shown that the ID of the caller is YYYYYY.
Now i want to configure that when i call from my cell number YYYYYY, router "answers" and ask me what extension do i want and when i type on my cell 222, my IP phone with that extension needs to ring.
Did anyone had same thing to configure?
All the best.
Assuming this is CME, you would need to configure BACD or some other script in order to get the prompt and then transfer it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi.
Just to add that you can find some info on what Jaime suggested (+ 5p) at this link
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080566c4a.shtml
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Jamie and Carlo thanks for replies. I am going to give it a try, hope i succeed.
@Jamie, yes it is CME.
Regards.
153
