Community Member
routing outbound calls thru specific voice ports
I have a CME systems that has both SIP and analog PSTN trunks. I would like outbound calls from IP phones to go out the SIP trunks.  I also want to attach a FAX to an ATA device but I need to send FAXes out the analog ports since FAXes over SIP doesn't work to well.  HOw can I do this?
Thanks in advance.
1 ACCEPTED SOLUTION
VIP Purple
Re: routing outbound calls thru specific voice ports
Diego,
The following link has a good example of how to do this.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Hope this helps.
Brandon
Hi, create a voip dial peer for your phone calls and a pots dial-peer for FAX like below:
dial-peer voice 1 voip
destination-pattern
session protocol sipv2
session target ipv4:
no vad
Hope your phones are already registered as SIP and your voice register global is configured.
I haven't configure the FAX port yet but it's pretty simple as FXO port configuration, you will need a pots dial-peer for that.
dial-peer voice 2 pots
destination-pattern
port
You might need some additional commands to active FAX protocol (as example:T.38), please google for it.
HTH.
Community Member
That's not quite what I mean.  The problem is for outbound calls.  I will have two dial peers with the same destination pattern.  For instance 9[2-9].......
The difference is one will be a Voip SIP port and the other an analog port.  So outbound calls made from a SCCP phone need to use the SIP trunk and when a FAX device places a call I need the CME to send it out on an analog port instead of the SIP peer.
So somehow I need the CME to match an outbound peer depending on which inbound peer is placing the call.
Diego
VIP Purple
Diego,
Hope this helps.
Brandon
Community Member
That certainly looks like what I need!!
376
