Community Member
Routing the calls to a specific fxo port based the source number.
Hi ,
I have a setup with a cisco call manager using h323 Voice GW. I would like a user to make phone call though a specific line / fxo port on the analog line.
What are ways to achieve this.
I have about 8 fxo lines and PRI lines in use by the other users.
Faizal
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Routing the calls to a specific fxo port based the source nu
See:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Please remember to rate useful posts clicking on the stars below.
Silver
Hello Faizal,
If I understand your requirements correctly you need the ability to route calls from a certain phone/line to a particualr FXO port.  There are several ways to do this but I will detail the one that I think would be easiest.
For the selected line set up a partition and calling search space - just for that line/device.  In the partition build new route patterns matching your outbound dial plan.  On each of those route patterns prefix the called number with a number/character that is not used as a leading character in your existing dial-peers on your H323 gateway.  Build new dial-peers to match that leading character and assign them to the desired FXO port.  As with all POTS dial-peers any explicit character match will drop that character, so you could drop not only the leading character at the dial-peer, but also any trunk access codes (0 or 9 or whatever) that the user dialed to get a trunk.
HTH,
Art
See:
199
