Rsetting Cisco Phone
Hi all
I wanted to know what keys do I  push to reset a cisco phone without going into CM.
I know there is a way to do it but I've never done it before and I wanted to find out so that
I can add that.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
What phone model?
If 79XX press Settings button and then **#** sequence.
On 99XX, 89XX models you need to find reset option from admin menu.
HTH,
Chris
What phone model?
HTH,
Chris
Thanks alot Chris, I just tried it and it worked perfect thank you.I there a list that can show you the commands that you can do from just the phone itself like the one that you just showed me.
273
