RSS FEED LINK
Can anyone help with rss feed link that can be used on ip phones
thanks so much
Bronze
Re: RSS FEED LINK
i used this last year when demoing for a customer.
http://dontpokebadgers.com/RSS2Cisco/
a google search also turns it up fine. basically, you download and install a program that contains modules, and install on IIS. ive W2K3 works fine. then edit the script accordingly to whereever you want to pull feeds from.
ive done this for managing directors that need thier football(soccer) reports and for one of our local news.
if youre jsut looking for a test link, then
http://www.berbee.com/public/berbeesoftware/XMLFree.aspx . scroll down and you'll see RSS
Re: RSS FEED LINK
i am trying to modify the script but have an issue.
how do i figure out the location the script will end at
Bronze
Re: RSS FEED LINK
put it in the inetpub - wwwroot folder.
146
