Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
RSVP Application ID support across CUBE
Has CUBE the ability to map RSVP application ID's across call legs? At present the configured application ID's we see on call leg 1 are not present in the RSVP reservation in call letg 2.
TJ
Re: RSVP Application ID support across CUBE
Hi TJ,
From what I can tell there isn't a way to change the default for this function. I'll admit I'm pretty lame when it comes to RSVP - would you like to expand on how you expect this to work and the implications?
-nick
Hi Nick
What we have is this scenario
phone--agent--agent/cube -wan- cube/agent--agent--phone
where the two phones are in different clusters. CUBE's connect cluster together.
Both Clusters are using RSVP sucessfully internally marking the reservations with the correct application Id's based on voice and video calls. Each cube acts as an RSVP agent in it resective cluster terminating the cluster side call.
The WAN call leg doesnt have any application ID, all is bundled into the default, so any WAN router wouldnt be able to determine based on policy the correct bandwidth for each application etc etc.
I was hoping that having the cube as an agent for CUCM it would terminate the internal call leg, and then recreate the wan call leg with similar application ID present, however this doesnt happen. If CUBE could re map the app ID it would give us proper WAN RSVP bandwidth policy control
Terry
Hi Terry,
Would you mind explaining exactly what the significance of the application ID is? I'm more on the voice side, and don't see RSVP too often.
thanks,
nick
130
