I want to run IPT on WAN. SO i configured my gateway at DC & Branch as RSVP Agent. But i think in Call Manager also i am required to do some settings. Can someone plz tell me what should be the settings look like in CCM for RSVP??
You have to add your RSVP agents to CM as MTP to match your config on router. When you create your MTP make sure phones in branch use correct RSVP agent by configuring MRG and MRGL.
Second you need to use locations and define your: Location RSVP Settings.
