Community Member
RTM Message IpVms
Hi.
Real Time Monitor has reported Alert kernel: IpVms: StreamMixer: Excessive mixer calls, Does anyone understand what this means as Google and CCO has not thrown any light on this? Should I be concerned?
Cheers
Richard
Re: RTM Message IpVms
Hi Richard,
Please check bug id:
CSCte19629    "Excessive  mixer calls" alerts from IPVms
Symptom:
IpVms media driver issues error to system log "Excessive mixer calls"
Conditions:
Other (unknown) system processes are causing the kipvmsMixer## process to
not be scheduled for execution for a period exceeding 100ms.  Since
kipvmsMixer## process is running at high priority (near RT) about the only
other processes that can interfere are system / kernel related.
Side-effect of this is the audio media being streamed from Media Streaming App
may have jitter issues at the end-points.  With no control over scheduling,
the application cannot do anything to reduce this.  Only possibly by reducing
work-load on the server (number of registered devices or call traffic).
Workaround:
Ignore the error message.
I hope this clarifies your question.
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Community Member
RTM Message IpVms
hi,
You may find the details in this bug fix CSCte19629 Bug Details
4445
